rubbing noise when turning left
Old Aug 18, 2011 | 8:19 AM
Bigdaddy95's Avatar
Default rubbing noise when turning left
Greetings !
I have a 2004 silverado 1500 ext. cab./ 85k
When turning left, at a slow speed, I hear a rubbing noise, (rubber?) and feel a slight vibration in the steering wheel.
no clunks or bangs like I've read about.
Steers fine, back roads, and hwy.
P/S fluid is full.....no leaks underneath.
serpentine belt is tight.
Can anyone out there guide me in the right direction please ?
Would like to do this repair myself.
Thank-you in advance.
Bigdaddy
Old Aug 21, 2011 | 1:49 AM
usmarine0905's Avatar
Could your tires be rubbing agaist the rubber spash sheild..??
Old Aug 24, 2011 | 1:23 PM
Bigdaddy95's Avatar
Default reply
Checked the splash sheilds..( thanks usmarine0905 )
Nothing rubbing there.
I will check underneath again.
Thanks, Bigdaddy
Old Aug 24, 2011 | 2:13 PM
slw210's Avatar
Wheel bearing.
Old Aug 24, 2011 | 3:20 PM
kevinkpk's Avatar
Originally Posted by slw210
Wheel bearing.
Could be. I'd suggest jack it up, and pull on the wheel to feel for any play in it.
Old Aug 29, 2011 | 12:58 PM
Bigdaddy95's Avatar
checked wheel bearing,No play in wheel.
Sounds like rubber against metal.
actually sounds like it's coming from the firewall
Old Aug 29, 2011 | 2:22 PM
kevinkpk's Avatar
Could it be the blower motor, since you say sounds like it is comming from the firewall?
Old Aug 31, 2011 | 6:09 AM
Bigdaddy95's Avatar
don't think it's a blower motor.
feels like it's in steering column.
I read there's an intermediate steering shaft.
Anyone have any insight??
Thanks !
Bigdaddy
Old Sep 1, 2011 | 12:05 PM
GM Fixer's Avatar
sounds like the seal that the steering shaft goes through at the firewall is dry. Spray some silicone on the seal. My truck does the same thing. it is a squeel/ moan sound.
Old Sep 2, 2011 | 6:33 AM
Bigdaddy95's Avatar
Yes.....that is the sound !!
I will spray it after work.
Stay tuned !
Thank-you.
Bigdaddy
