Seal replacement
Seal replacement
Can you install news seals (oil) front and rear with out pulling the engine .
1999 Chevy Silverado Z-71 4x4 any advice would be apprec. Thans
What old wrench is asking is there excessive crankcase (air/blowby) pressure in the crank case? You should go ahead and at least inspect the pcv valve with it removed, and engine running you should feel it sucking.
MissEmu
September 23rd, 2014 2:17 PM
braz28
October 20th, 2007 10:39 AM
