security alarm?
I want to install an alarm on my '95 1500, the problem is I don't know wheather Ineed a GM bypass module to install one. doesany body know? My next question is where is the electric door lock module located so Ican connect to it so I can have keyless entry?
Bypass modules are only needed if you are adding a remote start.
Doorlock wires can be found in the drivers kick panel.....light blue for lock and white for unlock....both positive pulse. The doorpin wire can be found at the light switch harness...purple wire negative trigger
The alarm I am looking at has rmote start, the dealership said that I didn't need one but I am not sure how smart the guy I talked to was. So I will need the bypass for my truck? When I had the guage cluster out last, the security light didn't have a bulb in it.
I don't think so. I asked the dealer a while back what it would cost to replace one of my keys and they said it would be like $10. So I don't think it has a chip in it.
Does any body know how to disconnect the 'hey stupid your lights are on" buzzer from the headlight switch? I have almost completed installing the alarm the one of the annoying things it doing is when I disable the alarm and the running lightscome on, so does the buzzer. Iwould like to disable it.
knarva
Apr 13, 2013 7:23 AM
