security alarm?
Old Mar 28, 2008 | 9:30 AM
northey87's Avatar
Default security alarm?
I want to install an alarm on my '95 1500, the problem is I don't know wheather Ineed a GM bypass module to install one. doesany body know? My next question is where is the electric door lock module located so Ican connect to it so I can have keyless entry?
Old Mar 28, 2008 | 10:36 AM
northey87's Avatar
Default RE: security alarm?
This is the bypass I was talking about.
http://www.jcwhitney.com/webapp/wcs/...pQ6Q%2Fg%3D%3D
Old Mar 28, 2008 | 8:28 PM
shawnvw's Avatar
Banned
Bypass modules are only needed if you are adding a remote start.
Doorlock wires can be found in the drivers kick panel.....light blue for lock and white for unlock....both positive pulse. The doorpin wire can be found at the light switch harness...purple wire negative trigger
Old Mar 29, 2008 | 1:31 PM
northey87's Avatar
The alarm I am looking at has rmote start, the dealership said that I didn't need one but I am not sure how smart the guy I talked to was. So I will need the bypass for my truck? When I had the guage cluster out last, the security light didn't have a bulb in it.
Old Mar 29, 2008 | 3:12 PM
shawnvw's Avatar
Banned
I'm pretty sure you won't need one....do you have a chip in the key?
Old Mar 29, 2008 | 3:19 PM
northey87's Avatar
I don't think so. I asked the dealer a while back what it would cost to replace one of my keys and they said it would be like $10. So I don't think it has a chip in it.
Old Apr 5, 2008 | 8:13 PM
northey87's Avatar
Does any body know how to disconnect the 'hey stupid your lights are on" buzzer from the headlight switch? I have almost completed installing the alarm the one of the annoying things it doing is when I disable the alarm and the running lightscome on, so does the buzzer. Iwould like to disable it.
Old Apr 5, 2008 | 11:03 PM
shawnvw's Avatar
Banned
Go under the dash and turn the parking lights on, listen for the buzz. It should be a rectangular plastic box at the fuse panel near your left foot. Just pull it out.
knarva
Apr 13, 2013 7:23 AM
cdella
Nov 2, 2007 8:41 PM
biglg
May 15, 2007 11:09 PM
hummrock
Nov 14, 2006 7:47 AM
Top
Follow Us
