Service parking sensors
Old Feb 14, 2011 | 11:59 AM
vette40509's Avatar
Default Service parking sensors
What can I do to turn off "Service Parking Sensors" warning that show in DIC on dash?
Old Feb 14, 2011 | 12:14 PM
jimmydow1's Avatar
disconnect the battery for 10 to 30 mins or go to autozone and they will clear the codes for free. but better yet have them serviced, because it will come back. you may try cleaning them, but that usually says "parking assist not available"
Old Feb 14, 2011 | 12:18 PM
vette40509's Avatar
They are not dirty. Just had right rear buper half replaced. I guess they unplugged and replugged the 1 sensor when changing. Its a 2009 if this helps.
Old Feb 14, 2011 | 12:29 PM
jimmydow1's Avatar
try just resetting the code then, by disconnect battery or autozone scanner. if it comes back on after then there is an issue
Old Feb 14, 2011 | 12:39 PM
vette40509's Avatar
Thanks, I am looking for soemone who "knows" what needs to be done, not guessing.
Old Feb 14, 2011 | 1:58 PM
jimmydow1's Avatar
Im not guessing, Im trying to help you. make sure they are plugged in, clean, check for power, check the fuse, then obstruct them, do you get an alert? if so you just have a code that hasnt reset, if not then you have bad sensors. there is no 1 thing only to diagnose your issue.
AK__21
Apr 24, 2013 7:25 AM
damoore2
Sep 10, 2010 7:12 PM
nighshifter
Dec 4, 2007 4:36 PM
lpmowles
Aug 8, 2007 6:33 PM
