Service Stabilitrak, Traction Control, LIGHTS come on when I let off the gas
Service Stabilitrak, Traction Control, LIGHTS come on when I let off the gas, but Service Stabilitrak, Traction Control lights turn off when i give it gas.
OBD2 codes showing
P 0107
P 0106
P 0113
I replaced MAP sensor twice each time i did the truck wont start. But when I DISCONNECT MAP SENSOR TRUCK STARTS and RUNS GREAT, BUT Service Stabilitrak, Traction Control CHECK ENGINE lights come on. I should mention I just had a brand new crate motor put in. I have put only 300 miles on new motor so far and Service Stabilitrak, Traction Control,CHECK ENGINE LIGHTS have been on ever since i got new engine put in. Please help. Thanks
OBD2 codes showing
P 0107
P 0106
P 0113
Would like to add that I recently started getting the SERVICE STABILITRAK and ABS warning lights when I tapped the brakes or sitting at a stop light. It ended up being the brake light switch. Cost me $21.99 at Autozone and fairly easy to replace.
