Old Aug 10, 2015, 2:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Lighting Guides
Print Wikipost
Silverado 1500 Daytime Running Lights/ Park Lights Not working
Old Jun 17, 2013 | 8:33 AM
  #11
westgl's Avatar
The other problem can be, that one or both of the DRL light bulb connector's can be burnt.
I am trying to decide whether or not to add a relay, to reduce the current, this should save this are from so much overload.
Has anyone else added a relay to the DRL lights to reduce the high amp draw down to a much lower draw?
Trying to decide whether it is high draw or heat from the lamp itself that is melting the lamp connector
Old Jun 17, 2013 | 9:47 AM
  #12
Might want to verify that the correct lamp bulb is installed if the socket is melting... Sylvania has a nice guild for seeing what bulbs are needed... -->
Lamp Replacement Guide
Old Jun 17, 2013 | 6:37 PM
  #13
westgl's Avatar
thanks for the link in2pro,
I have the 3157 that crosses to a 4114, or versy viso.
Old Jun 20, 2013 | 6:51 AM
  #14
Driftrage25's Avatar
I say pull the bulbs and forget about the dtrl's cause IMO they are a useless waste and look dumb but I'm as you say "old" school on that
Old May 9, 2017 | 2:02 PM
  #15
Karam Ahmed's Avatar
Default Drl
Guys I got a 2017 Chevy Silverado 3500hd, just installed new HIDs and I'd REALLY like to shut OFF the DRL so I won't end up burning the bulbs driving around in the Mornin with them on. My old model Denali I had was a 2014 I jus pulled the fuse and I was good. But can't seem to find the fuse on this one
Old Apr 22, 2026 | 9:15 PM
  #16
vikingm80m's Avatar
Default Both inner running lights out
I just bought a 2005 Silverado to use as a work truck. All bulbs work except for the two and are running lights on the bottom set. I put two new bulbs in and still nothing. One of the sockets looks kind of burnt orangey on the inside. Can I just change out the sockets for both of those? Or since they’re both not working is there something more than changing the sockets? They both look kind of burnt.
troutbum
May 12, 2015 7:45 PM
99_Silverado-2001_Z06
Feb 3, 2014 8:49 PM
Stanga05
Jan 15, 2014 12:41 PM
skdevore
Aug 26, 2009 10:18 PM
