Last edit by: IB Advertising
- Chevrolet Silverado 2007-2013: What Are Signs of Bad Transmission?
Guide to diagnose trouble and recommended solutions.
silverado 1500 shifting hard from first to second gear
#11
Silverado shifting hard
I am having the same problem with my truck but it doesn't do it all the time, if I go on a longer drive it will start shifting hard or if I get on a highway and get up to about 70 or 75 and then turn off it will do it but its hit or miss if it does it getting off the highway
#12
Hi Folks - Allan - new member here - sorry to revive old post, but it's closely related. you mention an easy fix to the 1-2 hard shift, if you haven' changed the fluid yet - Can you pleas describe it and does it also work for a hard 2-3 shift?
here's what's happening:
bought a 2007 Silverado Classic 4 1/2 years ago with about 70k miles on it. It had about a year left on an aftermarket extended warranty (which I didn't have alot of faith or experience in).
hard shift from 2-3 started before year was up and after 1 attempt to fix the dealership (via the extended warranty) came good for a supposedly $3000 remanned trannie with a 3 year warranty.
well, of course, just after 3 years later the hard shift has started again.
any help that - that would avoid spending big bucks on a used or another remanned unit would be appreciated.
#13
Allan, Have you resolved your problem? I have a 2012 Silverado w/similar problems. Shifts HARD at times, sounds like someone hit it with a sledge hammer. Dealer just told me that's normal.
Just curious what you've found out.
Thanks,
Terry
Thanks,
Terry
#14
Hard shift from 1 to 2
#15
A banging 1-2 shift is a very simple repair and no, the transmission does not have to come down.
First, check for codes. If none are found do the following:
Drop the pan back down, remove the 1-2 accumulator housing and pull the piston. Check for a torn piston seal or broken spring, but moreso for a wobbled out piston hole, which is probably the culprit.
Now, if all these items are okay, the 1-2 check is bad (unlikely). This is where it starts to get dicey unless you've been into about a million of these things, because the valve body has to come down (you don't even wanna go there).
I think you're gonna find a bad 1-2 accumulator piston. Wish you would have hollared before you changed the oil because you could have repaired this thing in just 10 minutes.
Allan
Allan
#17
Did you ever figure it out?
I'm having the same problem. Did anyone ever figure it out? I have an 09 Chevrolet Silverado 1500. 160000
#18
Having same problem
I’m having the same problems hard shift from 1-2. I changed the 1-2 accumulator and now it only does it once in awhile. Wondering if anyone figured anything ever about it?
#19
Allan
Allan
pickemuptrucks
February 6th, 2010 2:51 PM
gotstylez
19
February 5th, 2010 9:34 PM
melloyello
October 30th, 2009 9:25 PM
