Smog problems please HELP
Old Mar 26, 2015 | 10:48 PM
adsiemers's Avatar
Default Smog problems please HELP
my 2001 Chevy Silverado 5.3 .. is having a problem getting all monitors ready to smog. Evap, EGR, Heat Sensor, secondary air.. please help with suggestions. this has been an issue for way to long ... I have done the cycle.. changed all sensors twice . secondary air valves, cleaned mass air etc... I'm done putting money into it.
Old Mar 26, 2015 | 11:24 PM
any monitors running and failing?
Old Mar 27, 2015 | 11:05 AM
adsiemers's Avatar
there are a 5 that show ok and 4 that show incomplete. they check engine light will come on stating that I have low circuit volts on O2.
Old Mar 27, 2015 | 6:57 PM
mistaake's Avatar
I take it you've replaced all the O2 sensors (I think it's 4 in this truck?) and check to make sure the wiring is good? What's the actual code you're getting?
Old Mar 27, 2015 | 7:12 PM
the monitors will not run until the fault is repaired. the task manager knows that running a test with a fault present will produce a invalid result; so monitors are withheld.
ditto; post the code.
Mel83189
Mar 22, 2012 4:36 PM
mitchdakid
May 22, 2009 1:45 PM
k101979
Jul 20, 2006 5:42 AM
