Last edit by: IB Advertising
Browse all: Wheels and Tire
- Chevrolet Silverado 1999-2006 GMT800 How to Remove Spare Tire
spare tire
Hello all, new member & poster, I have a 2004 2500HD, is there any way I can lower the spare tire without the extension tools. I just bought the truck and just realized the tool kit didn't come with it. It has been a pain trying to find the kit thru chevy or a salvage yard. Any ideas would be welcome. Thanks!
Hi there, Cnwrails, welcome to the Chevy Forums.
I have the '04 2500HD. The last time I checked, the dealer wanted 239$ for that set, so I imagine it's even going to be rather rare at junkyards.
I had the same basic issue with my truck because the extensions wouldn't fit on the end of the spare tire lowering mechanism because my rear bumper had been hit a couple times.
1)Look under the bumper from the spot with the key-hole -( where the owners manual instructs you to insert the jack handle/extensions)- to the spot directly over the center of the spare tire.
2)You will see a black plastic tube.(the "guide" for the extension on a new truck, or one with a perfectly aligned rear bumper)
3)Gently remove that tube. Hey, screw it, RIP IT OUT.
4)Look at the point above the spare tire where the tube(used to) end. You will see the lowering mechanism for the spare tire. Looks like it's 3/8" square drive, 1/2", whatever.
Counter-clockwise to lower, clockwise to raise. You're welcome.
Another fun note, if you've got the original rims, more than likely they're the "E-rated" 80PSI 10-Ply- HD tires. Enjoy!
You can get a long 3/8 extension and put it through the hole in the back of the truck ( where the original pole would go) and use a ratchet to raise and lower it. That is what I do at work rather the pull everything out of peoples trucks.
