speaker installation?
Old Apr 26, 2007 | 1:42 AM
jay3250's Avatar
Default speaker installation?
Im installing speakers in the doors of my 1999 chevy silverado and i dont have a speaker harness..
What I plan on doing is cutting off the old harness and soldering the bare wire onto the new speakers.. My question is how will I know which
is the positive connection and which is the negative after the harness is gone?I want to get the correct polarity on my new speakers.
thanks..
Old Apr 26, 2007 | 1:59 AM
BrianE's Avatar
Default RE: speaker installation?
temporarily hook up a speaker and play some thing with heavy base the cone must move out when the base hits. Also you could get a Haynes manual that should have a wiring diagram in it. If you listen closely when you hook up a speaker and play music then reverse polarity the sound becomes slightly muddled switch it back and for and you can tell by ear when a speaker is in proper phase (polarity) this does not apply to subwoofers as they can be run in any phase depending on enclosure.
Old Apr 26, 2007 | 3:41 PM
jay3250's Avatar
thank you very much for the information. So the cone will move out whenthe bass hits and it is hooked up correctly, and vice versa if it is not?
thanks
Old Apr 28, 2007 | 10:50 AM
jiggsy's Avatar
From the factory Service Manual. These are for 1999 Silverado.
Left Front SPKR = Gray - / Tan +
Right Front SPKR = Drk Grn - / Lt Grn +
Left Rear SPKR = Yel - / Brn +
Right Rear SPKR = Lt Blu - / Drk Blu +
Hope this helps......
Old Apr 28, 2007 | 3:52 PM
BrianE's Avatar
You got it. Thats how it works.
usmc2037
Nov 30, 2022 11:29 AM
cecook
Apr 14, 2016 4:54 PM
Crueser
Feb 16, 2011 11:00 PM
jdkluck
Jun 2, 2009 10:22 AM
gm76053
Chevelle & El Camino
May 13, 2006 10:04 PM
