Speakers problem
Old Mar 11, 2013 | 9:35 AM
w002mia's Avatar
Default Speakers problem
Hello chevy fans
My front right speaker quit working ... i tested ohm on both front speakers..
they're 9.5 ohm speaker
Left has no resistance at all lol 0.00
right one resistance 3.66k ohm.
I'm a bit confused because the speaker with no resistance is the one working
anyone know what the problem is?
Old Mar 11, 2013 | 12:51 PM
Chevy uses cheap paper cone speakers. They do not last long and need to be replaced when acting up. When replacing buy a better speaker and it will last much longer.
Old Mar 12, 2013 | 1:56 AM
w002mia's Avatar
But i wanna know if the speaker is bad or just wiring problem.
It's always nice to save some money
Old Mar 12, 2013 | 6:28 AM
Jeff Collision's Avatar
At first you need to check the fuses. If both front speakers are not working, then either the fade control is set to rear speakers only, or the front speaker plug has fallen out. If so, you will need to check the fade control first. Check the speakers by connecting them to a known good channel and check the wires for continuity. If it's not, then it could be the head unit. You should replace it.
Kentchorder
Aug 27, 2013 7:51 AM
cyr0n3
Sep 25, 2011 11:29 PM
Ertsride1
May 9, 2008 1:35 AM
PoWeRs
Colorado
Jul 27, 2006 2:55 AM
