Speedometer Problems
Old Mar 9, 2009 | 4:12 PM
bigbluechevy92's Avatar
Default Speedometer Problems
I have a '92 K1500 with aprox. 230,000miles the truck is in good condition except the speedometer doesnt work it hasnt for about 2yrs it has a manual trans I have already replaced the VSS on the tail of the trans with no effect I also tried changing out the gauge cluster with one from an identical truck also with no effect. I think there might be some kind of module between the sensor and the gauge. Please help thanks.
Old Mar 9, 2009 | 10:42 PM
northey87's Avatar
You are correct. There is a calibation unit behind the glovebox, it maybe burned up, here this may help:
http://www.tbichips.com/drac/
Old Mar 15, 2016 | 3:04 PM
Scott McDermott's Avatar
Default Need help with speedometer . Same problem
GM DRAC/VSSB Calibration
Ok I have a 92 C3500 , 454 , 5speed 2wd . When I bought the truck the speedometer wasn't working , I assumed it was cable operated and no problem . So far .. I have replaced the VSS ( in transmission ) the DRAC , and the gauge cluster. I do get a VSS code when I drive it , and the brake light is dimly light . If I press parking brake it gets brighter , and I'm full of brake fluid . Other then throwing in a ECM , am I missing anything ? Thanks
JohnDeere
Jan 6, 2012 9:48 PM
Z71HatcH
Jul 26, 2008 9:05 AM
Z71HatcH
May 30, 2008 2:20 PM
nokidz
Mar 19, 2007 3:17 PM
txjohn65
Dec 7, 2006 10:36 PM
Top
Follow Us
