Squeaking from front drivers side wheel
ok...I have a squeaking noise coming from the front drivers side wheel on my 2007 Z71 4x4 silverado...not really sure what it is or where to start since it randomly happens mostly if the truck hasn't been driven, once i warms up it goes away and seems to also only happen with I press on the gas, if i let off the pedal it stops.
The truck is lifted with a pro comp 6" lift and just hit 100k miles
really like to at least narrow it down so if its a job i cant do i can least call and tell the shop whats wrong to get better $ on this job
any help on suggests will be greatly appreciated
things to check are brakes, bearing hub assembly, caliper bolts, ball joints. you can look at the tires, check for uneven wear, jack front end up, check for slop or play in bearing, spin tire while off ground, see if and where squeak is.
trackerdriver
September 20th, 2015 10:53 AM
jlpolicky
February 17th, 2015 2:04 AM
jmarkv
January 24th, 2012 8:21 PM
cdeal
August 19th, 2008 6:45 PM
