Stabilitrac bypass questions
New guy here with a 09 half ton silverado 4X4. I did a search and cannot find much on the stabilitrac except how to hold in the button 5 seconds to cut it off. Is there a way to totaly disable it that anybody has found? I don't mind cutting off the traction control when I need a little wheel spin, but the babysitter that kills the power when I go to countersteer is driving me nuts.
If I hold the button in for 5 or 6 seconds the first thing I see is traction control off and then stabilitrac off. If I tap the button again it should cut on just the traction control for straight line, or does that cut everything on again even though it says traction control on?
ahartman
April 28th, 2015 9:28 PM
jgrisenti
October 25th, 2008 3:29 PM
