Starting
Old Feb 2, 2013 | 9:23 PM
ToooTall1's Avatar
Default Starting
Having starting problems with my 2001 Silverado 1500 4x4 w/5.3l. After sitting for a short while engine will crank but not start. Giving it a little throttle it will start and run fine. Stop engine and then it will resart with no hesitation. I think there is a loss of fuel rail pressure so maybe a pump, any input would help. Thanks
Old Feb 2, 2013 | 9:52 PM
country_09's Avatar
Fuel pump is gonna be my bet...or the fuel pressure regulator
Old Feb 2, 2013 | 10:39 PM
Check valve in the fuel pump may be the problem. When the check valve goes bad the pump still works but the fuel bleeds back into the tank and no pressure is maintained. I put an inline check valve in the fuel line and that solved my problem.
quackpe
Jan 31, 2006 6:24 PM
billyjoe72
Oct 21, 2005 4:33 PM
aimin74
Oct 6, 2004 2:10 PM
