Starting Issues 98 k1500
Old Nov 14, 2010 | 3:22 PM
CLSZ7198's Avatar
Default Starting Issues 98 k1500
I have a 1998 K1500 5.7 and it is having issues starting. I can spray starting fluid into the intake and it will crank and run until I shut it off again. then I will have to repeat the same procedure with the starting fluid to get it to crank. Is this issue related to a bad fuel pump? I can hear the pump prime but it is rather quiet. I replaced this pump 2 years ago also.
Old Nov 14, 2010 | 9:21 PM
MDTAHOE's Avatar
Professional Mechanic
Sure sounds like a fuel pump problem. You need to check the pressure.
Old Nov 15, 2010 | 2:02 PM
CLSZ7198's Avatar
Update: problem was the fuel pump..thanks mdtahoe
joshm
16
Feb 9, 2015 12:07 PM
k150095
Aug 2, 2010 7:09 PM
k150095
Aug 1, 2010 8:43 PM
joshm
Dec 11, 2006 11:54 PM
