starting problem
![Mad](https://chevroletforum.com/forum/images/smilies/mad.gif)
Yesthe truck will turn over and over. i can spray some carb cleaner in the t body and the truck will start the first time.
Professional Mechanic
The one way valve in the pump or the regulator is bad. The fuel pressure has to be leaking down. How quickly does if fall off when you turn off the key. Very common issue on the Chevy truck
ffarv
April 9th, 2006 1:52 PM
