Steering Shaft
Old Feb 19, 2012 | 2:52 PM
dp77/00vette's Avatar
Default Steering Shaft
My mechanic says my steering shaft is what's making a poping noise when I turn. Is this possible and is it a common problem?
Thanks!
Old Feb 19, 2012 | 4:05 PM
grumpychevy's Avatar
Absolutely. It's called an intermediate steering shaft. Get one from Napa ( I paid around $70 ) and change it yourself. It took me about 1 hour with only a few tools
Old Feb 19, 2012 | 4:16 PM
Thanks grumpy, I may do that.
Old Feb 19, 2012 | 4:18 PM
This is a very common problem that alot of people with these trucks feel should have been a factory recall. This a the part of the steering column that collapses in a front end impact. Basically 1 shaft slides inside another shaft and when all the lube dries up or leaks out, there is no buffer left between these two shafts so they start making a clunking noise when you turn or hit bumps. This part of the steering linkage is what passes through the firewall connecting your steering column to your steering box. I hope this helps you out.
rich_ncal
Nov 23, 2008 9:51 AM
jjallou
Sep 2, 2008 7:54 PM
larryboy58
Feb 5, 2008 5:49 PM
cas
Oct 24, 2007 10:02 AM
bigsid
Oct 27, 2006 10:42 AM
