steering wheel swap help
Old Dec 12, 2008 | 8:57 PM
03 chevy's Avatar
Default steering wheel swap help
i have an 2003 silverado & 2000 sierra i want to remove the stock airbag steering wheels and install a non airbagwood steering wheel fromGRANThas anybody done this and if so how did you do it any help would be good
Old Dec 12, 2008 | 9:55 PM
x1cn18's Avatar
Default RE: steering wheel swap help
havent personally my buddy changed his in a 2000 and said it was fairly easyjust pulled the wheel and clockspring and went right in
Old Dec 20, 2008 | 7:43 PM
sw4bama's Avatar
I installed a Grant on my 1996 Z, its really simple....Unhook the battery cable before you start, if you look behind your steering wheel you will find four srings or clips that hold the airbag unit in the steering wheel, take a small flat head screwdriver and pop those clips loose via a small groove, then the airbag unit comes out BE EXTRA CAREFUL with the unit and lay it down ASAP so you wont take a chance on it going off, take the clock spring out, then your down to the nut that holds the wheel on, take it loose then use a harmonic balancer puller (or steering wheel puller) and pull the wheel off. It sounds a whole lot more complicated than it really is!!!
SuperTexan
Sep 13, 2012 6:39 AM
Jeff Enlightened Gaudreau
Jun 2, 2012 7:24 PM
BADROC
K5 Blazer
Nov 27, 2011 12:36 PM
cyberrkatz
Jan 31, 2011 8:54 AM
sm3earl
May 30, 2007 12:06 PM
