sticking brake
Old Jan 25, 2011 | 1:37 PM
ReelAl's Avatar
Default sticking brake
hi guys, reelal here, a newbie.
i have a1982 chevy 4x4 6.2 diesel with a sticking right front brake.
have replaced the caliper & the hose bled it and it still sticks. could
the proportioning valve cause this? when i replaced the hose fluid
did not run out. if it was the master cylinder would not more than one
brake lock-up? any help would be appreciated.
Old Jan 25, 2011 | 3:37 PM
tswiczko's Avatar
Did you clean the surfaces where the caliper slides on (The guide pins) And lubricate them?
A bad master cylinder usually goes to the floor.
I think a proportioning valve would be either a front or rear problem not just one front hanging up
bleed the whole system. and see if that helps.
EPOCH6
Jan 2, 2015 10:07 PM
jabres
Nov 28, 2013 2:01 PM
CMate
Sep 13, 2013 9:59 AM
oneStickySilverado
14
Dec 15, 2010 2:40 PM
linerunner
Dec 12, 2006 5:15 PM
