Stock stereo amp install?
Old Feb 18, 2008 | 5:57 PM
diskjocke's Avatar
Default Stock stereo amp install?
Im installing a high low onto my stock system to install a amp for some subs.. Now problem wich cables are for the speakers colors???
Left colors??? and right colors??? for the speakers please help asap im sitting in my truck
Old Feb 18, 2008 | 6:01 PM
northey87's Avatar
Default RE: Stock stereo amp install?
Welcome to the forum!!! Someone here should be able to answer your question, you just need to give them time.
Old Feb 18, 2008 | 6:22 PM
06chevy5.3's Avatar
whats the year and model?
Old Feb 18, 2008 | 7:10 PM
diskjocke's Avatar
2008 chevy silverado extended cab..i have all cables installed.. just waiting to find out what colors are left and what colors are right, for the high low converter to the stock stereo
Old Feb 18, 2008 | 7:51 PM
diskjocke's Avatar
Ok i think i figured it out.. yellow and brown.... now if im wrong correct me... but i ran into a new problem.. no dang remote cable on this truck..... Now anyone know where i can run the remote cabel for the amp
Old Feb 18, 2008 | 7:59 PM
shawnvw's Avatar
Banned
The is an access panel on the right side of the dash in the door jamb. pull it off and you will find a yellow wire that tests as RAP. some vehicles do not have the connector that houses the wire, but i belive you can pop out the junction block, and the wire will be on the backside
Old Feb 18, 2008 | 9:22 PM
diskjocke's Avatar
ok so your saying that the cables on the passenger side of the dash.... the yellow wire can be used for the remote for the amp.... to turn it on and off with the stereo?
Old Feb 19, 2008 | 4:04 AM
fireman526's Avatar
Go to www.mobileinformationlabs.comto get a wiring diagram for $10 for your vehicle. Makes things alot easier!! www.logjamelectronics.com sells line output converters with amp remote turn on wires built in for $25.
Old Feb 19, 2008 | 6:30 AM
e's Avatar
e
Left Rear Speaker:
Brown +
Yellow -
Right Rear Speaker:
Dark Blue +
Light Blue-
Old Feb 19, 2008 | 6:54 PM
shawnvw's Avatar
Banned
ORIGINAL: diskjocke
exactly
Top
Follow Us
