sunroof
i want to put a sunroof in my 04 silverado and am researching it but not having a good result. has anybody put in a sunroof in their truck? any problems with aftermarket sunroof vs factory installed?
I know that for the 07's and up the factory sunroof is designed to leak...
and that was a good idea...the factory one is not designed to be water tight so they built in a water channels and drain lines, and yes during a hard rain you can reach up above the lip and feel a bit of dampness, I like this because it deals with the water, where as an after market one may be water tight now but will it be after some time, and if it starts to leak you will have to deal with the leakage and possible staining.....
im pickin up what both of you are laying down. so with in2pro sounds like factory is the way to go and mdtahoe.. factory is the way to go since they install them on vehicles on the time. right?
dbergair
April 25th, 2008 3:56 AM
