sunroof
Old Jan 24, 2010 | 5:35 PM
s34n's Avatar
Default sunroof
i want to put a sunroof in my 04 silverado and am researching it but not having a good result. has anybody put in a sunroof in their truck? any problems with aftermarket sunroof vs factory installed?
Old Jan 24, 2010 | 7:42 PM
I know that for the 07's and up the factory sunroof is designed to leak...
and that was a good idea...the factory one is not designed to be water tight so they built in a water channels and drain lines, and yes during a hard rain you can reach up above the lip and feel a bit of dampness, I like this because it deals with the water, where as an after market one may be water tight now but will it be after some time, and if it starts to leak you will have to deal with the leakage and possible staining.....
Old Jan 24, 2010 | 9:56 PM
MDTAHOE's Avatar
Professional Mechanic
I would not be too keen on some guy cutting a hole in my roof, unless I knew that he REALLY knew what he was doing.
Old Jan 24, 2010 | 10:33 PM
s34n's Avatar
im pickin up what both of you are laying down. so with in2pro sounds like factory is the way to go and mdtahoe.. factory is the way to go since they install them on vehicles on the time. right?
Old Jan 25, 2010 | 6:45 AM
MDTAHOE's Avatar
Unless you replace the entire roof with a roof from one that had a sunroof you can not get a factory sunroof.
dbergair
Apr 25, 2008 3:56 AM
hairgod78
Jan 6, 2008 9:14 PM
jmitchell
Jun 7, 2007 6:04 PM
jumperchicki782
Jan 25, 2007 5:03 PM
Gman
Nov 15, 2006 10:38 AM
