synthetic oil
#31
I would even go so far as to say 85% of drivers actually fit into the "severe" category. I still wouldn't go anywhere near 25k on any oil. I don't see a reason to risk it. But I do believe it can be done and is done all the time. I don't know about paying that much for oil either.
I see the word "risk" thrown around alot, which is somewhat humerous. I guess there is "risk" in lots of things...flying in a plane, driving on public highways, skydiving.....but research shows us that when done correctly, most people suffer no adverse effects from doing these things. Yet for some reason when research shows that a company has made 25k oil and filters that work and work well, lots of people refuse to believe it can be done and call it "risky".
"Oil filters can't filter effectively after 5000 miles. They can be run longer, but I wouldn't go against the filter manufacturer's reccommendation.
That is, unless its a special kind of filter."
I think part of the problem here is that some are thinking of a $4 Fram, and a $20 AMSOIL EAO filter as the same thing and they are apples and oranges. Ready to have your mind blown???AMSOIL's EAO filter is recommended for 25k....the severe service oil, their "Signature Series", under normal driving conditions, is recomended to be changed at 37,500 miles. I hadn't mentioned that before due to the difficulty in getting you convinced about 25k changes...lol.
As I said before, if 3k and replace is what you are happy with, nobody is knocking it. But I have a question... How many tens of thousands of vehicles would have to do 25k oil and filter changes without being harmed in any way for some of you to believe it is not "risky"???
They are out there driving around you everyday, with millions of miles under their belt.
Just food for thought...
Be safe and have a good week.
#32
GOTCHA!!! Took me a while to get there. I must have overlooked the fact that you are using the deep and advanced Amsoil filters.
Amsoil is generations ahead of everyone else. I have seen some of their vacuum boil tests... you'd be surprised what Mobil1 does at 29"hg vac that Amsoil doesn't do!
Is the habit THAT ingrained? lol
Every policeman I have ever met (or been pulled by) says "Be safe and have a good day." or "Be safe and have a good weekend." etc. Right after handing you the ticket. lol
#33
Your points are well taken, but if a $100 oil change replaces 6 or 8 $25 oil changes, who is spending more money?
#34
Or to show his own lab results. But that would require a sample every 3000 miles....
Amsoil dealers are like Rainbow Vac dealers. Just regular people normally. https://www.amsoil.com/dealerlocatorresults/
There are a few retail stores.
#35
Danistheman1234
25
August 9th, 2011 5:16 PM
Danistheman1234
May 26th, 2011 6:59 PM
