take off and throttle reponse
when i floor it in my truck it takes awhile to get out of first gear and i want it faster out of the first two gears and better throttle response , any parts i can add to better this i already have a K&n cold air intake ,
1997 chevrolet crew cab c3500 5.7L longbed automatic
I remeber the shift kits from years ago, but I thought the new computer transmissions could be reprogrammed. I do know the common wisdom is that the automatic transimission spends time in both gears while shifting to smooth out the shift. This causes more wear on the transmission than having a kit which essentially is a spacer that causes the shift to happen faster and be a bit more abrupt and cause a little jerk for the riders. This also is supposed to increase your mileage a bit because you don't have two gears fighting each other.
gunrnr
Aug 31, 2010 9:18 PM
tom5170
Mar 16, 2010 9:41 PM
