throttle body spacer???
Old Sep 21, 2009 | 3:54 PM
89silverado283's Avatar
Question throttle body spacer???
ok i have an 1980 chevy scottdale 3/4 ton with a 350 and a 4 speed manuel, ok i have a few throttle body spacers laying around, i have an 1 inch and a 2 1/2 inch, i was wondering what would be the differents between: no spacer to/ 1 inch.. or no spacer to/ 2 1/2 inch???
Old Sep 21, 2009 | 5:09 PM
Mike Sigmond's Avatar
ROTM Coordinator
To be honest, if the rest of the motor is stock I doubt they will make any difference.
Old Sep 21, 2009 | 5:38 PM
myotherchevyisablazer's Avatar
it will be hard to tell the difference in power gains either way you go
Old Sep 21, 2009 | 6:14 PM
ok how about gas performance??
Old Sep 21, 2009 | 6:17 PM
ROTM Coordinator
Not that you would notice in my opinion.
Old Sep 22, 2009 | 5:01 PM
ok so what if i cam, port and polish and re build the heads, new rings, bearings, and maybe .30 bore, what would a spacer do then???
Old Sep 22, 2009 | 5:09 PM
ROTM Coordinator
I have no idea, just put it on and see if you like it, a dyno would only be able to tell the difference in my mind.
Old Sep 23, 2009 | 3:43 PM
ok sounds like a plan...
Old Sep 23, 2009 | 5:25 PM
gianelli280's Avatar
The only thing a tbi spacer did for me was make my idle higher. But SOMETHING on my engine is finally shiny!
Old Sep 25, 2009 | 2:50 AM
aukai22's Avatar
throttle body spacer does a little for your truck but not that much a little HP and a little gas mileage. if you have it you should just put it on. it won't hurt just to have it there and it makes a pretty cool whistling noise at lower rpms.
