Tire Pressure always low
Old Nov 20, 2011 | 8:10 AM
Agent86's Avatar
Default Tire Pressure always low
I have noticed that according to my in dash display on my 2011 Silverado 1500, all 4 tires are always reading around 28- 30 PSI, the MFG Spec calls for 35 PSI, however they dont get low enough to illuminate the low pressure light.
Ive had the dealer pump them up to 37 PSI a couple times and in a few days they are right back to 30 PSI. Anyone have any thoughts?
Old Nov 20, 2011 | 8:22 AM
JK23112's Avatar
A change in temperature is likely your culprit.
Old Nov 20, 2011 | 9:30 AM
Agent86's Avatar
Thanks, and yes I too contibute change of Temperature, but do you think that 5psi drop affect my tire wear or fuel milage? I was thinking of replacing the air with nitrogen, do you think that may help?
Old Nov 20, 2011 | 6:29 PM
shakydoug's Avatar
Mine have N2, they are 27 in the garage, shortly after 3 - 5 miles they go to 30 psi. perfect
Old Nov 21, 2011 | 1:24 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Agent86,
JK23112 makes a great point. Temperature is usually the culprit and is normal. If this issue continues to concern you, stop by your dealer and have them check it out. Best of luck!
Louis
GM Customer Service
damone
May 8, 2021 12:36 PM
MikeShirk
Dec 31, 2012 10:39 AM
erosenwinkel
Aug 26, 2011 11:10 AM
05uplander
Uplander
May 31, 2010 11:25 PM
BuyOuts
Nov 20, 2009 8:37 PM
