Tire Size
Old Feb 20, 2010 | 7:24 PM
taz3's Avatar
Default Tire Size
Does anyone know why the 4X4 trucks use a larger/taller tire the a 2X4 truck with the same options(engine & gear ratio)? My truck has 245 70 R17 and I'm debating going to the larger 4X4 size tire, for a variety of reasons, availability, cost (larger tire is more common) and the small tire looks lost in the wheel opening.
I always thought it was odd, because a 4X4 would have the extra drivetrain to rotate and would benefit from the extra torque of a smaller diameter tire.
Old Feb 20, 2010 | 10:29 PM
therewolf's Avatar
The higher tire profile gives the differential higher ground clearance.
The larger tires cope better with the off-road and heavy duty on road use to which a 4X4 is subjected to. A larger air cushion gives a better ride under harsh conditions.(In theory.)
Some of those larger tires, especially on the HD models, are also "E"- rated, 10ply,80PSI. Your basic tractor trailer radial construction. R-R-R!
tonymacias
2007 - 2013 (GMT900)
Aug 21, 2012 9:50 PM
slammerslugs
11
Aug 12, 2008 1:48 AM
313hitman
Feb 4, 2008 5:01 PM
WOODDOGG
Jan 29, 2007 11:17 PM
technoswede
Jan 3, 2007 9:15 PM
