tire size help
Old Dec 6, 2010 | 1:25 PM
passen1500's Avatar
Question tire size help
Can I fit 33" tires on my 95 1500 with no lift?
I'm planning on Yokohama Geolander AT-S 285/75/16s right now if they'll fit..
And how far would you suggest I tighten my torsion bars to level it? As far as I know everything is stock. I recently purchased the truck and have 28" road tires on the front and 31" MTs on the back right now... not sure why the guy who owned it before me did it that way.
Old Dec 6, 2010 | 4:54 PM
chevytilldeath's Avatar
if its a 4x4 the all u would need is the torsion bars adjusted 2 in or so, or the tires will rub badly,and it will clear 33s, its what i did on my 92 k1500.
Old Dec 6, 2010 | 5:36 PM
passen1500's Avatar
yeah its 4x4. I dont mind rub.. if its too much ill handle it later.
thanks alot.
Old Dec 7, 2010 | 10:46 AM
gotstylez's Avatar
my 95 required no lift for 33" tires... remember when you crank your t-bars..measure from the ground to the fender BFOR you start on a flat level ground...stick the front under some jackstands..if any lift..you'll know need to turn the t-bar bolt a few times..maybe 5? remember to do both sides the same..take truck off jack stands measure again maybe sure they are the same/real close
Old Dec 7, 2010 | 1:07 PM
passen1500's Avatar
thanks alot. i'll be sure to get it right the first time lol I dont want to fight to get them even. are those 33"s no lift in your pictures in your profile?
and for tightening the t-bars is that something that i can/should do by hand or with pneumatic? ive got pneumatic but i can imagine it would be difficult to judge the exact number of turns for it. maybe sharpie a line on the socket... hhmm..
Old Dec 7, 2010 | 2:19 PM
gotstylez's Avatar
i dont have any pics with 33's and no lift.. i do have a pic with 33's and a simple 3" block in the rear and the t-bars cranked all the way..ill post the pic here.. and if u mean the pic below..no its got 6" lift..3" body and 3" supension
Old Dec 7, 2010 | 5:55 PM
passen1500's Avatar
no i meant the pictures in your profile. the one in your signature thing is obviously lifted.
https://chevroletforum.com/forum/alb...pictureid=2119
Old Dec 7, 2010 | 6:16 PM
gotstylez's Avatar
ohhh..no those are the stock tires that had befor i got it.. 31" and no lift..
bigmitch
Feb 1, 2014 10:19 PM
tonymacias
2007 - 2013 (GMT900)
Aug 21, 2012 9:50 PM
pjr7269
Feb 29, 2012 1:53 PM
bongoz
Jan 5, 2011 2:13 PM
