TPS or Tire?
Old Jan 11, 2009 | 11:21 AM
Chas1955's Avatar
Default TPS or Tire?
I have a strange problem, when it gets cold 20 & below my LR TPS says the tire is low (30 vrs 34) I drove home watching & as the tire got wamer presure came back up to 34. This happened about 3 times & the one time I added air it went to 37 when it warmed up?
Old Jan 11, 2009 | 1:47 PM
TheBrettster's Avatar
Banned
Default RE: TPS or Tire?
Its normal, Cold weather promote's leaks as well. Make sure u manually check your tires often and you should have a problem. Air is very unstable thats why most luxury cars are running nitrogen now.
Old Jan 23, 2009 | 11:20 PM
jwruss's Avatar
In my opinion 34 psi is too low a pressure for your tires. I normally run 40 psi in mine and when loading heavy run 44.
Old Jan 24, 2009 | 7:08 AM
IAfarmer's Avatar
This is why I get very mad at the oil change place when they check tires. (I do my own changes on my vehicles, but not the company vehicles). The truck comes in off the highway. Tires are hot, which means they will read high. What do the guys do? LET OUT AIR. Now my tires are low.
Cold weather really messes with air pressure. When my truck did the same thing, I went around and checked the pressures and brought them back up. I run 38 PSI in my 07 NBS 4x4, stock tires.
Old Jan 24, 2009 | 3:27 PM
silveradocar's Avatar
Yeah! 34 psi is less you fill it upto 40 or 42 psi. Its a heavy vehicle.
fernandito7
Oct 3, 2007 5:08 PM
EliteDetailOC
Mar 27, 2007 12:13 PM
bobbyt
Mar 14, 2007 7:24 PM
EliteDetailOC
Mar 13, 2007 2:30 PM
amos221
Mar 6, 2007 10:41 AM
