TPS voltage @ IDLE & WOT ??
Old Jan 18, 2022 | 3:20 AM
Lorejel80's Avatar
Default TPS voltage @ IDLE & WOT ??
Hey guys, new to this forum and seeking some help!
I have a 2001 c3500hd with the 8.1L. I have codes p1220 & p1221. I changed the Tps sensor but still have same codes. I decided to check the tps sensor voltage just because it’s an aftermarket part. Hoping I did this right..here are the readings I got for the tps….
tps sensor #1
WOT - .35v
IDLE - 4.01-4.02v
CLOSED - 4.55v
TPS # 2
would have same reading of 4.85 through out the movement of the throttle body. It wouldn’t change at all! My question is: Is this normal? Does anyone know what the voltage should be??
any help would be very much appreciated 🙏🏽
Old Jan 18, 2022 | 7:57 AM
hanky's Avatar
If you were to look at the voltage waveform for the 2 TP sensors, they are opposite one from the other.
It would seem that TPS #2 is open for whatever reason.
billingstitan
1988 - 1998 (GMT400)
Aug 7, 2021 12:02 AM
nickmostly
Oct 12, 2019 12:22 PM
jlutty3
Mar 2, 2015 9:33 PM
Darren Fargo
Camaro
Dec 23, 2012 1:09 PM
gaftop1
Feb 22, 2008 2:35 PM
