Rochester Quadrajet TPS problem
Old Oct 8, 2019 | 11:47 AM
nickmostly's Avatar
Default Rochester Quadrajet TPS problem
Hello:
Newbie here hoping I might get help, this Throttle Position Sensor prob has me stumped!
The rig I’m working on is an 89 Chevy Caprice with the 305 olds engine. The code reader is reading 21, TPS voltage to high and 45, rich exhaust (make sense)
I have been consistently reading about 3.39 volts (on the middle connection that should have the voltage variation) no matter what position the throttle is in. I replaced the TPS and also the ICM (as it is called on the 305 olds engine) and the reading is the same, with a very small variation when the throttle is operated.
I then unplugged from the TPS and checked the voltage coming from the plug, the 5 volts is coming to the top wire, and BEHOLD the middle wire (that should have the varying voltage) is reading 3.39 volts when disconnected. Shouldn’t this read 0 or close when the TPS is disconnected? I suspect this is over-riding anything the TPS is trying to send.
When I first checked this is when I replaced the ICM. Still the same. I don’t have any visible shorts and suspect some type of Voltage Leak which is why I replaced the ICM, AC Delco parts. Any ideas?
Thanx much..
Old Oct 11, 2019 | 2:52 AM
Ricardowelch's Avatar
Originally Posted by nickmostly
Hello:
what rpm should my car idle at? Access Autoguysland site for more info if you concern.
Thanx much..
I see you post in another forum. hence, have you got the solution for this issue yet? You also refer this link for more info if it helps or not.
https://www.thirdgen.org/forums/carb...-problems.html
Old Oct 11, 2019 | 3:03 PM
kevinkpk's Avatar
With an ohmeter, unplug the connector, read the 5 volt reference side to the return side (3.39 volts you are reading), move the throttle off idle stop, the resistance isn't changing is my guess, that means the wiper on the resistor is bad, causing it to only read 3.39 volts.
Old Oct 11, 2019 | 7:39 PM
nickmostly's Avatar
Thanks Kevin:
I'm W/O a clue in this system, I have already performed the test you suggest, and it still reads 3.9. Is the resistor you speak of a red square one in the distributor? I saw this when I replaced the ICM, attached to the ICM. It looked as if it might have been replaced before, but I hadn't any idea what it was.
Thanx again.
Old Oct 12, 2019 | 8:42 AM
kevinkpk's Avatar
It is attached to the throttle arm, and moves a wiper across a fixed resistor. That changes the reference voltage depending on where the throttle is, i.e. half way, 2.5 volts etc. If it reads 3.39 regardless of the actual throttle position it needs replaced.
Old Oct 12, 2019 | 10:45 AM
nickmostly's Avatar
already replaced this.. bench tested it and it works fine..
the 3.9 is coming from the center wire that plugs into this
overiding the signal the tps sending. I'm trying to figure out where the 3.9 is coming from. seems it should be reading 0. Thanx
Old Oct 12, 2019 | 12:05 PM
kevinkpk's Avatar
Is it reading high unplugged? Could be a crossed wire or connection from the reference to feed back, not impossible, but not really likely
Old Oct 12, 2019 | 12:22 PM
nickmostly's Avatar
yeah.. not likely at all.. but there it is.. I'm tryin to find a decent wiring diagram and do sum circuit testing.. may spring for the shop manual, hate to tear into the harneses.. I was hoping sumone out here would have the magic bullet fix : ( thanx much!
ludachris777
Oct 8, 2024 6:28 AM
Zayne Snyder
Sep 6, 2017 1:13 AM
Mechman95
Dec 8, 2014 10:57 PM
gaftop1
Apr 22, 2011 11:20 AM
wayne220
Jun 28, 2010 4:31 PM
