traction control
Old Dec 2, 2013 | 7:08 PM
rdw99's Avatar
Default traction control
i am having a problem with my 2009 silverado. while driving the engine basically shuts down and on the dash i get the message of service traction control...then engine power reduced....then the engine light comes on and i have to pull over shut the truck off for a minute then start it back up. has anyone else had this issue?
Old Dec 2, 2013 | 8:16 PM
Official GM Rep
Hello rdw99,
We understand that this situation may be frustration for you, and apologize that you're experiencing these issues with your truck. We'd like to look into this further to research any recalls or Special Coverage bulletins related to the issue you are experiencing. In order to do so, can you please message us your VIN, current mileage, and dealership? Thanks, we look forward to hearing from you.
Amber N.
Chevrolet Customer Care
Old Dec 3, 2013 | 7:05 PM
3Horses's Avatar
Might have an issue with your "TPS" "Throttle Position Sensor" that was the issue with my 2011.
I have a 2011 Chevrolet Silverado 1500 this past March when I had around 52,000 miles on My truck went into a limp mode(Rough idle, no power, top speed about 40mph, hard trans shifts). I had three messages "Service Traction Control", "Service Stabilitrak", and "Engine Power is Reduced" messages also my SES Light and low traction warning lights came on. I limped it to a Chevy Dealer in the area I was in at the time, They found I had two codes: P2153 and P0121. Both related to my Failed TPS "Throttle Position Sensor" on my throttle body. They replaced the sensor, Reprogrammed the ECU and Reset the Idle. Total bill was about $260 for the repair on my truck. The new "TPS" fixed my issue and never had any issues since and I now have around 65,300 miles on her now.
See if you can get the codes first, might be the same issue as I had.
Old Dec 30, 2013 | 12:23 PM
ZachBerg's Avatar
I am having the same issue with my 2011 Silverado. Is it covered under the warranty?
Old Dec 30, 2013 | 12:43 PM
Official GM Rep
ZachBerg,
I am sorry to hear you are having this concern as well. We can certainly look into this further for you. Have you been able to have your Chevrolet dealership look into this yet? Please do not hesitate to reach out to us via private message.
EricaTiffany/some/det/gw1
Old Dec 31, 2013 | 4:15 AM
3Horses's Avatar
Depends on your mileage I guess, I had over 52,000 miles at the time so I was off warranty.
gofor35off
Feb 8, 2022 12:57 PM
pcwilcox
Oct 21, 2013 11:00 AM
warren
Apr 8, 2007 11:48 PM
