2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
traction control
Old Mar 20, 2006 | 3:38 AM
warren's Avatar
Default traction control
Has anyone experienced the traction control light coming on for no reason. Happened to me when i was travelling about 2mph and making a right hand turn. Road conditions were dry, and light braking while turning into my driveway. Also happened when i was just starting out from a stop and it was in heavy traffic so there was no excessive throtle being applied. This is a 2001 Impala LS with about 45,000 miles on it. Took vehicle into dealer and no code was found. Are there any tsb on this subject. Thanks
Old Aug 11, 2006 | 2:50 PM
car85freak's Avatar
Default RE: traction control
hey im having the exact same problem with my 2003 impala so if you find out wat causes it let me know but wat i do is if you turn the traction conrtol off when you first start the car each time it drives just fine.
Old Aug 11, 2006 | 6:20 PM
impala2k3's Avatar
I had that problem with my Impala also. I had the front abs controllers in the wheel hubs replaced by the dealer. It did solve the problem. Hope this helps!
Old Jan 2, 2007 | 1:25 PM
cindanz's Avatar
You probably have it repaired by now, but have you checked the level of brake fluid in your master cylinder?
Old Mar 11, 2007 | 5:33 PM
mightydog4805's Avatar
i have a 2004 impala and my traction light doesn't work, when i hit the button nothing happens
whats up?
Old Mar 16, 2007 | 10:35 PM
mikemjohnson's Avatar
you should ride without it on, its more fun
i have never had this problem, id imagine an ECU problem or something - 2000 pala here
Old Mar 19, 2007 | 7:25 AM
drwalker88's Avatar
check your front tire pressure. My brother-in-law's was doing the same thing. His driver-side tire was 2 pounds less then the pass. side was.
Old Apr 8, 2007 | 11:48 PM
hey! my traction control on my 2004 impala is stuck...so now i can't turn it off.
any sugesstions on how to fix it...i kinda want to
oh yea...if i wanted to get a cold air intake for my impala...can u get one for a 3.4L or does it have to be a 3.8L
thanks
gofor35off
Feb 8, 2022 12:57 PM
pcwilcox
Oct 21, 2013 11:00 AM
slotcanyoneer
Cobalt
Mar 3, 2008 1:14 PM
