Trans. temp ?
Old Oct 30, 2011 | 4:34 PM
namu mac's Avatar
Default Trans. temp ?
I have a 2004 6.0l 2500 4L80 trans and 4:10 gears. After about 350 mile trip pulling a utility trailer loaded maybe 2000-2500 #. the trans. temp gauge was reading about 200-220 degrees I got a message of Transmission Hot in the message center. Why, the trans temp reads hotter than that when I pull my 9000# boat. I checked the fluid and it was full and hot to the touch but not super burning hot. I am confused to say the least.
Old Oct 30, 2011 | 10:30 PM
OLD WRENCH's Avatar
The fluid goes thru the coolant which is running at least 200 degrees so that temp shoul be about right.
Old Oct 31, 2011 | 8:15 AM
kevinkpk's Avatar
I'd suggest if your going to pull trailers, boats add a transmission cooler.
Old Oct 31, 2011 | 9:59 AM
namu mac's Avatar
There is a trans cooler. This truck has 134k miles and has never shown the trans. hot message. the trip home the temp gauge never got over 175. I'm not concerened about the 250 temp, as I have seen that seveeral times pulling my boat up hills and always goes down to about 200. the question is why the conflicting info. the trans temp gauge and the trans hot message werenot giving the same info. What gives?
Old Oct 31, 2011 | 10:12 AM
kevinkpk's Avatar
I'm not talking about the radiator cooler, but an external add on.
Old Oct 31, 2011 | 11:05 AM
country_09's Avatar
Just as he said, but it probably does have a tranny cooler stock. But it's a little one. Get a tru-cool 40k and don't look back
Old Nov 1, 2011 | 6:52 PM
namu mac's Avatar
I understand about adding an aftermarket cooler. The real question is why am I getting conflicting info. I have pulled this trailer with approx. the same load on this same trip many times. Some withe the outside temp. much warmer with no trans. hot message. Why is the gauge reading in the low 200 degrees and the message says the trans. is hot. Do they both get their info. from the same sensor, or are there 2 sensors?
Old Nov 1, 2011 | 7:37 PM
kevinkpk's Avatar
[quote=namu mac;196435]I understand about adding an aftermarket cooler. The real question is why am I getting conflicting info. I have pulled this trailer with approx. the same load on this same trip many times.quote]
You've answered your own question
Old Nov 1, 2011 | 8:49 PM
Not true.. the thermostat in the engine maintains the engine temp at or about 195f... the coolant in the radiator is generally much cooler and is the "cold" reservoir for the engine when the thermostat opens and closes to maintain that temp...
Old Nov 2, 2011 | 7:27 AM
OLD WRENCH's Avatar
There always has to be one on every forum, adios boys.
