Transmission fluid filter
Old Dec 16, 2006 | 9:12 PM
brims's Avatar
Default Transmission fluid filter
I'm thinking of installing an external transmission filter since the internal one is referred to as a rock filter. I know Perma-cool sells an external trans filter kit, they only list 2 filters that work with that kit. What about using a remote engine oil filter kit and a regular engine oil filter? Would there be any problems with this? If I can do that then I'll only need to buy 1 kind of filter. Thanks.
Old Dec 17, 2006 | 2:34 PM
RAT454's Avatar
Default RE: Transmission fluid filter
You can and it does work well. However most adapters only use a select few filters and most are not metric...so you may still have to buy different filters...
I ran that setup on a 1 ton 454 turbo 400. i changed the filter every once in a while. I cut it open once and it did filter out very small particles...
Greg
Old Dec 17, 2006 | 4:51 PM
brims's Avatar
Since you've done this and it worked well then at least I know it's not a completely crazy idea. Thanks for the reply.
Coravir
Oct 26, 2019 3:28 PM
rcott
Nov 17, 2012 1:20 AM
junklady
Oct 28, 2009 6:01 PM
bwaple
Mar 6, 2008 8:30 AM
