Transmission or TCM bad?
Old Jun 24, 2023 | 4:30 PM
branedge's Avatar
Default Transmission or TCM bad?
Put a new diff in (went from 3:43 to 3:72) when truck changes to 2nd transmission slips (no noises) if I put in manual Reverse and 1st fine, even holding brake and giving gas no slips. I tried starting in 2nd and 3rd high rpm no power. When use OBD2 reader shows gear ratio 8 which is shows like an error limits are 1-5 according to reader.
I have dropp8the transmission pan no metal shavings or burnt smell.
Thinking of replacing the TCM, I've pulled it out and ohmed the solenoids (all seem good).
I have access to an autel maxisys odb2 reader that lets you turn the switch solenoids off and on. When I do this I don't hear any noise, I tired this on a 99 and a 2014 and I can here them click on and off.
This is driving me crazy! Any help would be greatly appreciated!
Old Jun 24, 2023 | 8:53 PM
changing the gear ratio requires reprogramming the PCM/TCM and EBCM, or it won't shift or brake correctly, and possibly damage the transmission.
Old Jun 24, 2023 | 9:14 PM
branedge's Avatar
We just bought a Diablo tuner because someone else told me it needed to have the gear ratio changed. Can you tell me if you think this will program it
https://www.summitracing.com/parts/dbl-9245
Old Jun 24, 2023 | 10:54 PM
no idea. ask their tech support.
Keisha
Oct 9, 2022 8:18 AM
Dan DuBief
Sep 16, 2022 6:23 PM
reagan102
Mar 2, 2022 11:19 PM
bcalhoun0126
Sep 10, 2016 12:50 PM
malibunut
May 7, 2008 8:23 PM
