Truck still Shakes
I am at a loss: Truck continues to shake between 60 - 70 mph and the ride is considerable rough/bouncing:
History:
06 Silv LS modes:
22's 305/50/22 tires
New Adjustable Gabriel HiJacker shocks in the back
Brakes have been checked (good)
Tires have been balanced twice
Alignment has been done twice and I have replaced the tie rods
For the past 4 days I have taken this truck to two shops and they both say the have it fixed but the shaking is still very annoying at the speed given above. I do realize that the comfort of the ride will be different given the change of wheels/tires but come on this is horrible.
I don't know what else to look for to change in order to, at least, stop the shaking/vibrating at 60-70 mph? Where do I go from here? I'm tired of dropping it off at the shop every morning and hitching a ride!
Suggestions? YES - I have used the "search" feature but nothing seems similar to my problem?
History:
06 Silv LS modes:
Is the truck a 1/2 ton or 3/4 ton?
Is there any load in the bed?
I know my truck is very rabbity at higher speeds until I put a few hundred pounds in the bed, and 50/22s are going to tend not to diminish any ride roughness.
Also, look very carefully at the stabilizer bar links. They have a tendency to go pop off sometimes, and they don't show any ride roughness at lower speeds.
What's the mileage? Is there any chance the driveshaft is misaligned, or possibly a U-joint is defective?
Sorry about that 06 Silv 1500 LS with only 80K, no load in the bed. I haven't hauled in it since I changed out the tires. I already knew my quality of ride would deminish from previous wheel/tire combos on my other trucks but this seems different than normal.
I'll have to look at the stabilizer bar. I am not sure about shaft/u-joint, could I use what I have read on the board about driving down the street and turning the engine off to take the load off the shaft?
Okay, so I found that even though the wheel/tire balanced one of the rims were warped. So I got that shop to replace the rim and the mother f still shakes!!! I am so fed up withs I am considering going back to my stock wheels/tires. I don't know what else to do?
If you have the stock wheels and tires available to you that might be a good sanity check is to put them on and see if the ride changes and if it is the new tire/wheels you may have to decide if the rougher ride is acceptable...
you may also want to try adjusting the tire pressure, full tires with no load can be bouncy...
