truck wont move need a hand diagnosting the problem
Old Jan 12, 2014 | 6:55 PM
matt552's Avatar
Default truck wont move need a hand diagnosting the problem
Hey i just got my 1997 chevy silverado z71 it was working fine until i stoped for 15 min when i went to take off it revved out and dintnmove and when i put it in park the gears grindit wont move in any gear and when left it park its still in neutral any idea on what it could be
Old Jan 14, 2014 | 2:08 PM
mel902's Avatar
Best case scenario-your linkage cable might have broke or un-hooked.
Worst case-your trannie is baked.
Old Jan 14, 2014 | 3:53 PM
Allan In NE's Avatar
Manual shift transfer case? If so, you've bumped 'er up into neutral. Been on many a service call on this "problem".
Allan
Old Jan 14, 2014 | 6:25 PM
matt552's Avatar
thanks...the 4x4 is on buttons and the truck is automatic how could i check if it is the linkage cable ?
Old Jan 14, 2014 | 7:16 PM
Put the emergency brake on, have someone move the shift lever while you crawl under the truck to see if the shift lever is moving.
Allan
Old Jan 14, 2014 | 10:28 PM
mel902's Avatar
I was talking to a friend tonite who had a similar problem.
He said he drove home ,shut the truck off and went inside.
Came out a few minutes later , started the truck and put her into drive and nothing.
He trouble shot it for about an hour and found out the transmission filter fell off inside the pan.When the truck was running it was fine but once he shut it off the vacuum from the pump stopped and the filter fell down to the bottom of the pan.
He popped of the pan and sure enough the filter was just floating around,so he replaced it ,put the pan back on and topped up the fluid and it worked fine.
Old Jan 15, 2014 | 4:51 AM
Yes, if someone had prior installed the wrong filter.
Allan
Old Jan 15, 2014 | 9:15 AM
mel902's Avatar
Allan
This is what i was thinking too but the filter was never changed only the trannie flushed.
The guy that it happened to is a heavy duty mechanic and that is why he came to this assumption.
Old Jan 15, 2014 | 3:37 PM
matt552's Avatar
i tryed that and yeah the shift lever moves so it must mean my tranny is gone?
dberladyn
30
Jun 24, 2015 10:28 PM
backcountry
Oct 19, 2009 10:13 PM
typhoon4x4
Camaro
Nov 7, 2007 10:57 PM
suggashak
Apr 22, 2006 4:48 PM
