Turn signal issue '02 Tahoe
Last week I started to have a problem with the turn signal in my 2002 Tahoe Z71. All of the lights would flash rapidly, and the side I was activating would burn the brightest. The rear Cyclops light also flashed. Immediately I replaced the flasher under the dash, that didn't work. Armed with a lot of information, I decided to order a new turn signal and install it. THAT DIDN'T WORK EITHER!! After some addition trouble shooting, I discovered that the problem ONLY happens when the parking lights (or headlights) are on. That is even weirder!! I have removed EVERY relay and fuse related to those lights. It doesn't fix it. Although... when I removed the fuses for the front parking lights, the problem slowed and seemed better. Then I removed the rear parking lights, that ALMOST made it stop, but there was still a faint flashing of the other turn signal flashers on the opposite side. PLEASE HELP!!!
Yes... lots of suggestions pointing to that. That is my project tomorrow. I will pull each bulb out one at a time to see of that is it. Thanks! Steve
fishingpro77
HHR
August 4th, 2016 12:44 AM
RomanGuzi
October 2nd, 2011 11:40 AM
