Turn Signal Mirror
Old Nov 26, 2012 | 6:53 PM
dgriffith's Avatar
Default Turn Signal Mirror
I bought a set of these off of amazon..anybody know tr easiest way to install them and how I wore them easily? I figured there was a way to just pop te mirror glass out instead f removing the whole door panel. Any help would be appreciated. Thanks.
Check this out on AMZN: iJDMTOY Universal 14-SMD Side Mirror LED Turn Signal Arrows, Brilliant ... http://amzn.com/B008B86O7Q
Old Dec 6, 2012 | 10:43 AM
dgriffith's Avatar
I finally got mine installed and it was pretty simple. Makes the truck look awesome. I will try and post some pics of mine soon. Below is the installation steps and everything you need to do the installation. It is a great add on for those that want the LED turn signal arrow for so cheap.
Side Mirror LED Turn Signal Arrow Lights
  1. Disassemble the mirror and test the mirror LED arrow lights. (what I mean by this is take the arrow and make sure it fits your glass properly, also you should test that the lights actually work off your positive and negative terminals on battery.)
  2. Tape the LED arrow light on the back of the mirror.
  3. Remove mirror cover. (Use small flat head scredriver to pop mirror assembly out) (Use Hairdryer to heat up plastic so mirror will pop out)
  4. Route wire to car body.
  5. Route wire to headlights and tap wire into the turn signal.
  6. Tape off wires and reassemble everything.
Tools Needed:
  1. Small Flat Head Screw Driver.
  2. Hair Dryer.
  3. Wire Strippers.
  4. Black Electrical Tape.
  5. Wire.
All in all this takes about an hour to do both mirrors. Of course if you take your time and do everything properly like I did. Its a simple installation. Thanks guys.
fishingpro77
HHR
Aug 4, 2016 12:44 AM
RomanGuzi
Oct 2, 2011 11:40 AM
psuter
May 7, 2011 5:18 AM
zfcastle
Mar 9, 2009 5:36 PM
myco01975
May 22, 2007 10:32 AM
