Unable to remove differential filler plug
Old Aug 23, 2010 | 8:29 PM
ve4aaz's Avatar
Default Unable to remove differential filler plug
I have a 2001 chevy silverado 1/2 ton RWD. On the last oil change the boys in the pit couldn`t unscrew the differential filler to check the fluid level. Up to this last oil change it would unscrew ok . Anyone have ideas what caused it to seize between oil changes or how to loosen it . I tried a little of liquid plumber but no joy. Do I need to use a breaker bar instead of my 12 inch rachet. What damage if any if use a electric heat gun to loosen the filler plug.
No bad sounds from the rear end just want to loosen the filler plug for the next oil change in a couple of months..
Thanks
Bill
Old Aug 23, 2010 | 11:06 PM
s34n's Avatar
try pb blaster. if you use the heat gun on low heat it might work. maybe try having someone loosen it while another person uses a hammer against the diff. the vibrations might loosen the plug.
ConverseNation
Apr 28, 2012 1:55 PM
Tashier
Mar 5, 2012 10:05 PM
russpmc
May 26, 2011 8:33 PM
bouchmpd
Oct 6, 2009 8:30 PM
Rayzun
Site Feedback
Nov 8, 2007 8:58 AM
