under load missing
Old Jul 5, 2012 | 2:50 PM
billyb19's Avatar
Default under load missing
My 88 c1500 w/ 5.7 misses under load. Plugs and wires are new. what else could cause this?
Old Jul 5, 2012 | 3:03 PM
kevinkpk's Avatar
Is it carb'ed?
Old Jul 6, 2012 | 6:36 AM
Allan In NE's Avatar
Do a compression test.
Allan
Old Jul 6, 2012 | 1:04 PM
billyb19's Avatar
Throttle body injection. Truck has 318,000 miles on it. Original coil(could this be the culpret?). I rebuilt engine at 152,000. Don't remember if I replaced distributor cap. Plan on checking it out. Just drove the truck this morning and it ran fine for a while(two legs of about 3 miles) but when backing it in driveway it started missing.....somewhat of a different deal since it wasn't really under load. Guess I will have to do a compression check. Real pain with the headers I have on it! Another piece of puzzle, MAP sensor is only 8000 mi. old. Was told by a mechanic that MAP and trottle position sensor are only 2 sensors that affect the way it runs under load. Can a MAP go bad that quick?
Old Jul 6, 2012 | 1:53 PM
kevinkpk's Avatar
What you are describing sounds like fuel schedule, but that usually is a problem from the git go. However, electronics can do goofy things when the heat up. The map sensor, was it new, and not el cheapo?
Old Jul 6, 2012 | 10:44 PM
jgray152's Avatar
How long has it been since you replaced the fuel filter?? My 97 silverado 5.7 did this and I replaced the filter and it runs great now
dslemaire
Aug 23, 2018 9:46 PM
jaysranger
May 9, 2015 3:10 PM
melat70
Aug 7, 2009 11:29 AM
rteas48183
Mar 18, 2008 4:59 PM
harold
Apr 6, 2007 3:20 PM
