Uneven front brake pad wear
Old Aug 14, 2011 | 8:46 AM
smkeeling's Avatar
Default Uneven front brake pad wear
I have an 08 Silverado LT 4x4. The outside front pads have worn down to nothing on the top edge roughly 1/2" down while leaving at least 3/8" wear on the bottom of the pad. The back side pad is worn out flat on both side (pass and drivers). The only thing I can contribute to this is the caliper design by chevy, it doesn't cover the distance of the pad. The front of the caliper leaves almost 3/4" with no pressure being applied to it. My camaro Z28 caliper takes up the entire bracket while the one on the silverado leaves tons of room. Any one else seen this wear issue? Has chevy changed the design or said anything? Seems like a safety issue.
Old Aug 14, 2011 | 11:33 AM
Mille Racer 69's Avatar
Maybe upgrade to an aftermarket caliper if it is indeed the design.
Put some Brembo's on there!
Old Aug 17, 2011 | 11:55 AM
Official GM Rep
Have you brought this to the attention of your local dealer? I can also look into this with your VIN. Please feel free to keep me posted either way. Thank you in advance.
Tricia, GM Customer Service.
RazzMaTazz
Mar 18, 2015 7:09 PM
nvestysly
Jan 22, 2014 2:49 PM
nate_o23
Jan 2, 2012 1:18 PM
negozio@verizon.net
Sep 26, 2009 3:42 PM
bigal1985
May 9, 2006 6:28 PM
