vibration
Old Sep 29, 2009 | 9:11 PM
noslocars's Avatar
Default vibration
<TABLE border=0 width="100%" itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD vAlign=top width="100%" itxtvisited="1">
</TD></TR></TBODY></TABLE><TABLE border=0 width="100%" itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD vAlign=top width="100%" itxtvisited="1">
</TD></TR></TBODY></TABLE>anyone had problems with frame vibrations on 99-2005 silverados? If so how did you fix it? I had a good ride until I put 10 ply tires on and now my ride is very bad. Lots of vibration and my front end of the truck feels very loose. I am ready to buy new tires or sell the truck. Please help!
Old Sep 29, 2009 | 9:18 PM
Speedy650's Avatar
did you mess with anything when changing the tires? or was it just a simple off with the old, on with the new swap?
Old Sep 29, 2009 | 9:41 PM
noslocars's Avatar
Just a tire change. No alignment or anything. I had the tires rebalanced thinking it would help but it didn't
Old Sep 29, 2009 | 9:48 PM
MDTAHOE's Avatar
Professional Mechanic
I think you need the balance checked again. Look for a shop that can do a roadforce analysis. Google roadforce tire balance or Hunter GSP9700 to see what that is.
Old Sep 30, 2009 | 11:21 AM
therewolf's Avatar
Cool
If your steering seems a little loose at highway speed, or you are taking too long to recover from a turn or bump, possibly your steering stabilizer needs to be replaced. The OEM units are POS, get at least a Monroe or Gabriel gas unit.
Old Oct 1, 2009 | 10:13 PM
silverado08's Avatar
make sure they didn't put way to much air in the tires. that would cause it to ride like a log wagon
Old Oct 2, 2009 | 10:31 PM
lukemoore646's Avatar
i know warped rotors will do it while on the brakes but I have heard of them doing it all the time too, does the steering wheel shake or the whole truck?
Old Oct 3, 2009 | 8:42 PM
Flying Low's Avatar
Ride of the Month
May 2008
From: Millbrook,Alabama...Slap dab in the middle of God's country
Have your tires checked for high spots. Sometime the heavier tires are not as "true" as standard tires.
David
Old Oct 4, 2009 | 8:02 AM
Chas1955's Avatar
If you have a 2500HD it may need a mod to the rear end or drive shaft. On my old 05 2500 HD I had a viberation from the day I picked it up. Someone at the local Chevy Dealer to find some kind of a recall for some 2500HDs' I don't rembemer what they did, but the viberation stopped. This was after the draler had balanced the tires twice.
Old Oct 5, 2009 | 7:45 PM
noslocars's Avatar
Well I went down and had my tires road force balanced and they were way off and there was no options to get them within tolerance. I bought a new set of BFG all terrains and my truck is now smooth as silk and no more wandering down the road. I should of never tried to buy something different than BFG's. Lesson Learned
