vibration in '94 z71
Old Feb 15, 2012 | 9:59 PM
CooperZ's Avatar
Default vibration in '94 z71
have a vibration at 60mph plus.....have checked front end all seems fine, u joints ok....any suggestions? Just had tires replaced?
Old Feb 19, 2012 | 11:04 AM
cleveland63b's Avatar
steering wheel vibration or seat vibration?? and how did you check the ujoints- removed driveshaft and moved them around?
Old Feb 23, 2012 | 9:34 PM
CooperZ's Avatar
seat of the pants.....grabbed drivehsaft with both hands and jerked around on it. Called guy at tire shop and he said he would rebalance tires...sounded like the tires to him....but have not got around to that yet because it is back in the tranny shop and that was just rebuilt about 4 months ago!!
Old Feb 23, 2012 | 9:41 PM
tx4x4's Avatar
Have you checked the front hub bearings on your truck?
Old Feb 24, 2012 | 1:05 PM
Fishinfooleric10@aol.com's Avatar
If it didnt do it before you got the tires replaced, I go with getting them rebalanced before you start lookin at parts. I've had the same problem before
Old Feb 24, 2012 | 9:44 PM
rule of thumb is if its in the seat then its more than likely from the rear of the vehicle, personally I'd pull your rear driveshaft and move the ujoints around. I wouldn't be surprised if 1 of them is seized up or has a spot that catches
Tires is another likely cause but you actually need equipment for that, driveshaft just simple tools and you'd rule out a factor
Old Feb 25, 2012 | 8:42 PM
CooperZ's Avatar
I have not checked the hubs and it definately feels as if it is coming from the rear. Will have to wait to get it back from tranny shop to check things out.
Old Feb 25, 2012 | 11:51 PM
might try giving them a call, if they're doing trans. work than more than likely the shaft is out and it'd take seconds to check the ujoints
Old Feb 26, 2012 | 12:49 PM
nkh34's Avatar
True story id call them if they already have it down it will save you the hassel and either fix it or rule it out. but if you just got new tires and then it happened its likley the tires. and just for safety alway check your lugz after the tire people i saw the schwabs guy driving a brand new dodge a week ago down our main street making sure the new tires rode smooth it was a customers truck and i watched the front drivers side tire pass him and the hub hit pavment hard and that happens alot more then you would think
linux2
Jun 23, 2014 9:40 AM
99ChevyZ71
14
Aug 29, 2012 8:22 AM
jgray152
Feb 19, 2012 11:12 AM
greatwhite99
Aug 27, 2011 4:00 PM
dmames08
Feb 24, 2006 11:53 PM
