water leak into heater blower motor
Old Mar 1, 2010 | 9:55 PM
usmarine0905's Avatar
Default water leak into heater blower motor
Hi, my 98 C2500,5.7 Vortec extended cab has a water leak into the heater blower motor. when the truck sits and it rains, water finds it's way into the blower housing. Anyone have any idea where this might be coming from??
Thanks
<!-- / message -->
<!-- controls -->
Old Mar 2, 2010 | 3:11 PM
ristpin's Avatar
Sure it's not anti-freeze? Does it have a "sweet" smell? Sounds like a leaky heater core to me. Check your radiator fluid level.
Old Mar 2, 2010 | 3:19 PM
Rodehard's Avatar
if leaf debris has clogged the drain holes in your fresh air intake, it will run in that area of the cab.
Old Mar 2, 2010 | 7:38 PM
MDTAHOE's Avatar
Professional Mechanic
Remove the wiper arms and then the cowl panel, you will most likely find crud in there causing water to go in to the box.
Old Mar 2, 2010 | 8:37 PM
@ rispin....its not antifreeze...just water. it only happen after it rains but thank you....
Old Mar 2, 2010 | 8:39 PM
@ MDTAHOE.....and RODEHARD....Thank you I will check that out this weekend. Also is it difficult to replace the blower motor assy, its started sqelling very baddly??
Splathapy
Jan 5, 2023 11:26 AM
scorpion48
Jul 20, 2011 9:44 PM
mathblaster
Nov 2, 2009 5:33 AM
BlackhawkCrewchief
Oct 11, 2009 10:26 PM
ljwnevpl
Nov 22, 2006 4:30 PM
