What am I leaking & from where.... (Pictures)
Old Jan 9, 2011 | 3:07 PM
BayAreaChevyGuy's Avatar
Default What am I leaking & from where.... (Pictures)
Okay I THOUGHT I was leaking oil from my oil pan gasket (according to the oil change place).
Oil is not red last time I checked??
Does it look like its leaking from that bolt? Is that the oil or tranny drain?
Old Jan 9, 2011 | 6:52 PM
usmarine0905's Avatar
Red fluid is normally tranny fluid. if you have red fluid on your oil pan, you could have a front tranny seal leak. that is the seal that goes between the tranny oil pump and the torque converter, the torque must be removed to replace the seal.....
Old Jan 9, 2011 | 7:28 PM
ramnj's Avatar
Had the same thing happen to me in a GMC Jimmy I had. It was the transmission oil seal.
Old Jan 9, 2011 | 7:42 PM
RacerX's Avatar
Maybe its blood. And your car is a crazy homicidal maniac like Christine or the bad Knight Rider car?
Old Jan 9, 2011 | 7:58 PM
The fluid looked red until I touched it and then it looked brown in my hands. I dunno. Im taking it to the shop tomorrow to be checked out. Tired of this bs.
Old Jan 9, 2011 | 7:59 PM
Oh by the way. WTF. I went to go check the inside of my oil cap and I couldn't get it off. Not sure if im retarded or what today. It just wouldnt turn or pop off.
Old Jan 10, 2011 | 2:11 PM
no engine oil is not red.... a rear main seal could also be leaking...
Old Jan 10, 2011 | 11:43 PM
tinbender59's Avatar
red then turns brown when transfered to a rag "that my friend is trans fluid" check your trans fluid level!!!
Old Jan 11, 2011 | 1:08 AM
I kinda feel stupid. I went and checked under the truck that day and that red that you see in the picture that I thought was red fluid turned out to be some sort of plastic something attached to the drain plug.
Im thinking when I took the truck back to the oil change place, and they checked the work. Do you think they put some kind of sealant around the drain plug, and this could be that? I checked and checked again but couldn't find the exact leak, or any other evidence of red fluid.
Old Jan 11, 2011 | 1:09 AM
In the picture I posted you can actually see a drip of the fluid on the right hand side of the picture about to drop.
