what to do? what to do?
Old Jan 17, 2011 | 1:22 PM
robertehess's Avatar
Question what to do? what to do?
i want to start tightening my suspension for better control with corners and the such. but where should i start? my truck is a 01 silverado 1500 regular cab with a short bed.
Old Jan 17, 2011 | 2:16 PM
Welcome to the forum..
a good place to start is replacing the rubber sway bar bushings and end links with polyurethane ones
Old Jan 17, 2011 | 8:12 PM
wmiller1337's Avatar
Lower it. Better handling and looks!
Old Jan 18, 2011 | 1:12 AM
mdseeker's Avatar
I agree with using polyurathane sway bar bushings Performance suspension technologies PST.com if not satisfied try bilstein shocks and max psi in tires
Mdseeker
For the fun
Old Jan 18, 2011 | 2:06 PM
i like it at the height its at with the leveling kit i saw a silver silverado with chrome 22"s i didnt like the way it looked but a lower center of gravity is a good start but i need to find other ways
Old Aug 17, 2011 | 6:32 PM
danadane's Avatar
Default Newbie... Noise in front suspension... HELP !!!!
Just purchased a 2002 Silverado 1500. 5.3L 4X2. After I bought it, I noticed
a clunking sound when you take off and when you slow to a stop. I replaced
a bent tie rod and both swaybar link pins and it didn't help. Thinking about
replacing all the ball joints. Maybe the control arm bushings. It's been awhile since I done mechanic work......any ideas?
Old Aug 19, 2011 | 9:57 AM
slw210's Avatar
A clunking sound on take-off and stopping would be U-Joints or differential or maybe transmission.
Old Aug 19, 2011 | 2:32 PM
country_09's Avatar
it'll be either u-joints or where the driveshaft goes into the back of the tranny, the piece that goes into it has teeth and they have to be greased up or it'll feel like you're gettin hit from behind when you take off
Old Dec 10, 2011 | 10:27 PM
high desert jim's Avatar
Slip joint spline lube. They have to use the factory spec Spline lube, not just grease.
That will get rid of the clunking on takeoff.
Old Dec 11, 2011 | 1:48 PM
GM Fixer's Avatar
Check frt bearings. and bushings
